Create Shape Inputs
Use the Shape tool to create shape design variables based on selected shapes.
Do one of the following:
- From the Design Explorer ribbon, Inputs tools, click the
Shape tool.Figure 1.
- Click the Shape tool satellite icon
. In the Inputs dialog, Details tab, click
Shape tool.
Select shapes in the following ways:
- On the guide bar, click
. In the Advanced Selection dialog, select a shape then click OK.
- If shapes are turned on in the model, select a shape from the modeling window
The input is added to the Design Explorer Browser. By default, a shape variable's upper and lower bounds are chosen as 1.0 and -1.0 respectively. These can be modified in the Inputs dialog or from the Entity Editor. - On the guide bar, click
