Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
In the steps below, you will create zero length elements and review.
This tool creates zero length elements (CELAS*, CGAP, CMASS* and CBush) from
disconnected nodes within a given tolerance. It also has the ability to disconnect
selected congruent nodes and create zero length elements.
From the menu bar, click Aerospace > Connections > Zero Length Elements.
Provide the correct tolerance to detect disconnected nodes within that
tolerance.
There is no need to select nodes manually, they are autodetected.
Activate the Quick Find Coincident Nodes option and
click Apply.
The nodes that are disconnected display.
Activate the Create Between Disconnected option and
click Apply.
0D elements are created.
Click Cancel to delete the created
elements that are not satisfactory.
Figure 1. Find Disconnected Nodes Automatically (Apply) Figure 2. Create Elements Between Disconnected Nodes
