Edit Cards
Edit an entity's card. You can edit multiple entities provided they use identical card images.
This option displays the card image of the chosen entity for the current solver template; if a template is not loaded or if the entity does not have any card images associated with the loaded template, an error message displays in the status bar.
Select entities in the modeling window, then right-click and select Card Edit form the context menu.
The Card Editor panel opens.
For more information on editing cards, see the Card Editor Panel topic.
Tip: You can also select Card Edit from the context menu in the Model Browser and Solver Browser.
