Make Entities Current
Determine which collector new entities are placed in.
Available for the following entity types: BeamSection Collector, Components, Load Collector, Multibody
View new features for HyperWorks 2020.
Explore the HyperWorks user interface.
View controls enable you to control the view and display of your model in the modeling window.
Quickly find and open the tools, panels, and browsers that are available from the ribbons or from the Utility Browser, as well as create entities and solver cards.
Select and deselect entities to modify with other HyperWorks tools. Selected entities are outlined to indicate their selection state.
Translate, rotate, and align the model.
Measure length and angles.
Obtain the mass, area, and/or volume of a selected group of elements, solids, or surfaces.
Learn how to manipulate entities in HyperWorks.
Learn the basics of working with entities.
Add entities to the model.
Modify entity parameters.
Remove entities from the model.
Duplicate selected entities.
Change the name of entities.
Move or copy entities between collectors, assemblies, and include files.
Change the display color of entities in the modeling window.
Change the display of an entity's geometry and mesh in the modeling window.
Edit an entity's card. You can edit multiple entities provided they use identical card images.
In Review mode, you can review selected entities irrespective of their display state.
Open the Reference Browser and display the relationship of selected entities to other entities in the model in a hierarchical tree structure.
Set various states for entities in a model.
Learn how to work with entities using the Entity Editor.
Undo and redo actions performed in HyperWorks.
Configure the view and behavior of HyperWorks.
Default keyboard shortcuts and mouse controls.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
ON THIS PAGE
Any new components, loads, beam sections or multibodies are created within the respective current collector.
ON THIS PAGE
