Change the Geometry and FE Style of Entities
Change the display of an entity's geometry and mesh in the modeling window.
Select entities then do one of the following:
  • In a browser, click the Geom/FE style icon and select an option.
  • In the Entity Editor, click the FE style or Geometry style field and select an option.
FE
Wireframe elements skin only
Shaded elements and mesh lines
Transparent elements
Shaded elements and feature lines
Shaded elements
Geometry
Wireframe geometry
Shaded geometry and surface edges
Wireframe geometry and surface lines
Shaded geometry
