Perform Batch Repair
Use the Defeature: Batch tool to perform automatic cleanup operations on selected surfaces.
Defeature: Batch Tool
An overview of the Defeature: Batch tool.
![](../../../images/icons/icon_batch_repair.png)
- Access
- Go to .
Options
- Target element size
- The target element size for the mesh.
- Stitch edges within tolerance
- The tolerance used to stitch surface edges.
- Allow T-connections
- Allow T-connections (non-manifold edges) to be created during the stitching process.
- Suppress construction edges
- Suppress unnecessary geometry construction edges.
- Delete duplicate surfaces
- Find and delete duplicate surfaces.
- Fix overlapping surfaces
- Fix overlapping surfaces based on an automatically calculated tangency angle.
- Remove edge fillets
- Square off any fillets/rounded edges located on free edges and having radii below the specified value.
- Remove if radius <
- Edge fillet radius.
