OptiStruct
For the most part, OptiStruct uses the same checks as HyperMesh. However, OptiStruct uses its own method of calculating Aspect Ratio, and it does not support 3D element checks.
- Aspect Ratio
- Ratio between the minimum and maximum side lengths.
- Chordal Deviation
- Chordal deviation of an element is calculated as the largest distance
between the centers of element edges and the associated surface. 2nd
order elements return the same chordal deviation as 1st order, when the
corner nodes are used due to the expensive nature of the
calculations.
Figure 1. Chordal Deviation - Interior Angles
- Maximum and minimum values are evaluated independently for triangles and quadrilaterals.
- Jacobian
- Deviation of an element from its ideal or "perfect" shape, such as a triangle’s deviation from equilateral. The Jacobian value ranges from 0.0 to 1.0, where 1.0 represents a perfectly shaped element. The determinant of the Jacobian relates the local stretching of the parametric space which is required to fit it onto the global coordinate space.
- Length (min)
- Minimum element lengths are calculated using one of two methods:
- The shortest edge of the element. This method is used for non-tetrahedral 3D elements.
- The shortest distance from a corner node to its opposing edge (or face, in the case of tetra elements); referred to as "minimal normalized height".
Figure 2. Length (Min) - Skew
- Skew of triangular elements is calculated by finding the minimum angle
between the vector from each node to the opposing mid-side, and the
vector between the two adjacent mid-sides at each node of the
element.
Figure 3. Skew of Triangular Element - Warpage
- Amount by which an element, or in the case of solid elements, an element face, deviates from being planar. Since three points define a plane, this check only applies to quads. The quad is divided into two trias along its diagonal, and the angle between the trias’ normals is measured.
