Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
1D mesh that allows accurate testing of connectors, such as bolts, and similar rod-like or bar-like objects that can
be modeled as a simple line for FEA purposes.
Volume mesh or "solid meshing" uses three-dimensional elements to represent fully 3D objects, such as solid parts
or sheets of material that have enough thickness and surface variety that solid meshing makes more sense than 2D shell
meshing.
Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply
shapes for subsequent design optimization studies.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
Use the elemental YZ manipulator as an incremental offset manipulator in elemental
systems.
The elemental YZ manipulator acts on the whole selection of beam elements. Each
manipulation along the Y or Z-axis will append that amount to every selected element
regardless of their current offset value. This tool is not meant to assign the same
resulting offset value to all selected elements. Instead, the selected elements will
be updated by the exact same increment. Figure 1.
Click on the appropriate element in the model.
Click the Elemental YZ manipulator tool on the microdialog.
Two arrows will display on the model representing the Y and Z
axis.
Click on the Y arrow, type a value for the offset, and press Enter.
Click on the Z arrow, type a value for the offset, and press Enter.
If you need to reset the offset, press the Reset offset
button on the far-right of the microdialog.
Note: This is not an Undo operation. Reset will always set to 0,0,0 regardless
of previous value.
