Offset Bar2 Elements
Manually set offsets or adjust beams on plates.
Introduction
Beam element shear center matches with an element's grids by default. To reposition elements at locations other than actual grids, you can offset the start node and/or end node. Offset components of each end can be resolved in the displacement system or in the elemental system.
Access the Offset tool from the Mesh ribbon by clicking 1D Mesh > Offset.
Figure 3.
