Property Selection (Optional)
In this optional step, you can select elements that can be assigned properties or a beam section.
If an element configuration type is selected, the list of properties will be filtered based on the selected type. For example, a Config Bar2 with type CBAR will keep only PBAR and PBARL properties, while a type CBEAM will keep only PBEAM and PBEAML.
If a beam section is selected, the property will be automatically created based on the element configuration type and will be assigned to the elements that are created.
From the guide bar, select either Property or Beam Section.
