FeedBack Controller
Some of the controllers can be coupled with primary controllers (discussed above) as secondary controller. The PID controller is one controller which can be used as both primary, as well as a secondary controller.
Use Case
- Integral control coupled with Feedforward longitudinal controller reduces the steady state error (if any).
- Slip Controller added on top of other controllers prevents vehicle from slipping.
[MANEUVER_1]
TASK = 'STANDARD'
(CONTROLLERS)
{DRIVER_SIGNAL PRIMARY_CONTROLLER ADDITIONAL_CONTROLLER}
STEER FEEDFORWARD_STEERING NONE
THROTTLE FEEDFORWARD_TRACTION I_CONTROLLER
BRAKE FEEDFORWARD_TRACTION I_CONTROLLER
[I_CONTROLLER]
TAG = 'PID'
TYPE = 'FOLLOW_VELOCITY'
DEMAND_SIGNAL = 'DEMAND_SPEED'
I_ACTIVE_BAND = 3
KI = 100
