Point Macros Toolbar
The Point Macros toolbar provides you quick access to the Create Points using Coordinates, Create Points Along a Vector, Create Points Along a Curve, and Create Point at Arc Center macros.
Figure 1. Point Macros Toolbar
Create Parametric Points | Allows you to create a set of points with respect to a reference marker either in Cartesian coordinates or Cylindrical coordinates. |
Create Points on a Vector | Allows you to create a set of points along a vector. |
Create Points Along a Curve | Allows you to create a set of points along a curve. |
Create Points at At Arc Center | Allows you to create a point at the center of an arc. |
Create Curve From Points/Nodes/Edges/Faces | Allows you to create curve graphics from a set of selected points or nodes. |
