Subsystems Toolbar
The Subsystems toolbar provides you quick access to the NLFE Stabar Subsystem, NLFE Helical Spring Subsystem, and Belt-Pulley Subsystem dialogs.
- NLFE Stabar
- NLFE Helical Spring
- Belt-Pulley
Stabar (Stabilizer bar) and Helical Spring can be used in automotive applications for the suspension. Helical springs can also be used in various other applications.
Figure 1. Subsystems Toolbar
From the View menu, select
and then click on a toolbar name to turn the display on/off for the selected toolbar.![]() |
NLFE Stabar Subsystem |
NLFE Helical Spring Subsystem |
Belt-Pulley Subsystem |
