Stabilizer Bars
The stabilizer bar helps to control body roll on turns. The Assembly Wizard allows selection of two types of stabilizer bars, single piece and two piece.
Front and rear suspensions use different system definitions of the stabilizer bar. The stabilizer bar connects the left and right wheels and therefore primarily acts like a spring and thereby reduces vehicle roll. The stabilizer bar can be used in either a half vehicle or a full vehicle models. The following stabilizer bars are supported in the Truck Library.
Stabar with Links
2-Piece Stabar with Links
