OS-T: 5030 Buckling Optimization of a Structural Rail
In this tutorial, you will perform a size and shape optimization on a structural rail to increase the buckling factor,
thereby increasing the load it can carry before buckling. The rail has external forces applied at one end, and is
constrained in all degrees of freedom at the other end. By performing buckling optimization, the buckling factor can
be increased and thereby increase critical buckling force.
