/ANIM/SHELL/TDEL
Engine Keyword Generates animation output for the time at which a shell element is deleted. The rupture time is output only for elements which are deleted, due to a /FAIL criterion. Failure criteria built in materials are ignored.
/ANIM/SHELL/TDEL
- To view the contour in HyperView, activate .
