Batch Mode Start Options
Start options for running Compose in batch mode.
Option | Argument | Description | Platform Support |
-f | <filename>.<extension> | Runs a script specified by the file. Requires absolute file paths as the argument (separated by ','). |
All supported platforms. |
-help | None | List the options when invoking Compose in batch mode. | All supported platforms. |
-input | <space separated inputs> | Passes input(s) to scripts. These options can be accessed in Compose by the OML commands
getcmdinput and getnumofcmdinputs. To pass
cell arrays or matrices on Linux, the open/close braces
and semi-colons need to be quoted. Linux example: -input ‘{‘ 1,2,3 ‘} ‘[‘ 4 ‘;’ 5 ‘]’ stringA Windows example: -input {1,2,3} [4;5] stringA |
-e |
Runs the OML command specified after the –e option. If multiple commands exist, they are separated by a comma and executed in the order provided on the command line. -e disp('a') -e "a=3 , rand(3)" |
