.h5 file
A binary file, containing model and result data.
Important: This is different from the .hdf5 (old)
file format which contains only the result data. Refer to PARAM, HDF5 to switch between the
.h5 and .hdf5 formats, or if both
formats are desired.
File Creation
The .h5 file is created when the HDF5 format is chosen (FORMAT and OUTPUT).
File Contents
The .h5 file contains the following results.
- Result
- Description
- Composite ply strain
- Ply strain results for composite materials from Linear Static, Nonlinear Static and Normal Modes analysis.
- Composite ply stress
- Ply stress results for composite materials from Linear Static, Nonlinear Static and Normal Modes analysis.
- Displacement
- Displacement results from Linear Static, Nonlinear Static, Normal Modes and Linear Buckling analysis.
- Element force
- Element force results from Linear Static and Normal Modes analysis.
- Grid point force
- Grid point Force results from Linear Static and Normal Modes analysis.
- Applied Load
- Applied Load Results from Linear Static analysis.
- SPC force
- Single-point force of constraint results from Linear Static and Normal Modes analysis.
- MPC force
- Multi-point force of constraint results from Linear Static and Normal Modes analysis.
- Strain
- Strain results from Linear Static, Nonlinear Static and Normal Modes analysis.
- Stress
- Stress results from Linear Static, Nonlinear Static and Normal Modes analysis.
- In case of Linear Static and Normal
Modes analysis,
- The supported element types for element-based results (in
.h5 format) are:
Result Elements Supported FORCE/ELFORCE CBAR, CBEAM, CONROD, CTRIA3, CTRIA6, CQUAD4, CQUAD8 STRESS CROD, CBAR, CBEAM, CONROD, CELAS1, CELAS2, CBUSH, CTRIA3, CTRIA6, CQUAD4, CQUAD8, CTETRA, CHEXA, CPENTA STRAIN - Corner results are also available for the above results with CQUAD4 and CQUAD8 elements.
.h5 format) are:
- In case of Nonlinear Static
analysis,
- The supported element types for STRESS and
STRAIN results (in .h5
format) are:
Result Elements Supported STRESS, STRAIN
CROD, CELAS1, CBAR, CBEAM, CTRIA3, CTRIA6, CQUAD4, CQUAD8, CHEXA, CPENTA, CTETRA - Corner results are also available for CQUAD4 and CQUAD8.
- DISPLACEMENT, STRESS and STRAIN results are also available on-the-fly during the analysis, if the NLOUT entry is defined in the subcase.
format) are:
- In case of Linear Buckling analysis, only DISPLACEMENT result is available in .h5 format.
