Remesh Tessellated Models
Use the Mesh to create new surface mesh on converted geometry.
The Mesh tool works for tessellated geometry. If the input is b-spline geometry, first convert to discrete geometry using the Convert tool.
Mesh Tool
An overview of the Mesh tool.
- Access
- Go to .
Options
- Average size
- Set the average element size for surface meshing.
- Curvature based refinement
- Option to turn on mesh refinement based on geometric curvature.
- Minimum size factor
- The minimum element size, as a factor of the average element size. Value must be less than or equal to 1.
- Geometric feature angle
- The maximum allowable break angle between adjacent elements.
- Growth rate
- The factor to control the rate of transition in case of element size change.
- Mesh element type
- Select the type of elements used to create the mesh.
- Mesh element order
- Defines order of mesh to generate.
- Treatment to connected mesh
- Defines what to do if surfaces adjacent to selection are meshed.
