::SetCloseButtonText
This command sets the text in the button that is used to close the wizard dialog.
::model::mdlWizardDlg::SetCloseButtonText text
MotionView Tcl GUI
text
The text that is to be displayed in the button that closes the wizard dialog.
To set the text for the button that closes the wizard dialog to “Done”:
namespace eval ::my_wizard {
    variable p_dlg ""
proc ::my_wizard::Run {} {
    set mangle [::model::GetMangle my_wizard_Run]
    variable p_dlg
    set p_dlg [::model::mdlWizardDlg wiz$mangle -width 600 -height 400 \
        -title "My Wizard" -showExport false -callback "::my_wizard::OnClose"]
    ::model::mdlWizardDlg::SetCloseButtonText "Done"
    ::model::mdlWizardDlg::ShowDialog
proc ::my_wizard::OnClose { args } {
    variable p_dlg
    hwt::UnpostWindow $p_dlg
    return 1
::my_wizard::Run
None.
