poINote GetTransparency
Gets the transparency attribute value (true/false).
poINote_handle GetTransparency
HyperView Tcl Query
This command returns the transparency attribute value (true/false).
To get the transparency of a note:
mySessionName GetProjectHandle myProjectName
set pageIndex [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $pageIndex
set windowIndex [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $windowIndex
myWindowName GetClientHandle myPostName
set modelIndex [myPostName GetActiveModel]
myPostName GetModelHandle myModelName $modelIndex
myPostName GetNoteHandle myNoteName [myPostName AddNote]
myNoteName GetTransparency
None.
