poISCL SetNumberOfPoints
Sets the number of points on the the Stress Characterization Line (SCL).
poISCL_handle SetNumberOfPoints num_pts
HyperView Tcl Modify
This command sets the number of points on the the Stress Characterization Line (SCL). The beginning and end points are included. The default value is 40 (specified by the Preference File).
- num_pts
- The number of points.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_ctrl
result_ctrl GetStressLinearizationCtrlHandle stresslin_ctrl
stresslin_ctrl GetSCLHandle scl_handle scl_id
scl SetNumberOfPoints num_points
hwi CloseStack
None.
