poISymmetry GetRectPattern
Gets the parameters which were used for a rectangular copy.
sym_handle GetRectPattern axis
HyperView Tcl Query
This command returns the parameters which were used for a rectangular copy. The return value contains the number of items along that particular axis and the spacing between items.
axis
The axis for which the parameters are requested. Possible values for this argument are: 0, 1, or 2 (corresponding to x, y, z axis).
To get the rectangular pattern parameters:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetSymmetryCtrlHandle sym_handle
set xval [sym_handle GetRectPattern 0]
set yval [sym_handle GetRectPattern 1]
set zval [sym_handle GetRectPattern 2]
hwi CloseStack
Returns an empty string if an error occurs.
