Radioss to PAM-CRASH 2G Conversion Mapping
Elements
Radioss | PAM-CRASH 2G |
TRUSS | BAR |
BEAM | BEAM |
SPRING | SPRING |
SPRING+PROP/SPR_BEAM (TYPE 13) | SPRBM |
SH3N | SHELL |
SHELL | SHELL |
BRICK | SOLID |
TETRA44 | TETRA44 |
ADMAS | MASS |
SPRING+INTER/TYPE2 | PLINK |
SPRING+PROP/KJOINT(TYPE33) | KJOIN |
RBODY | RBODY |
Boundary Conditions
INIVEL | INVEL |
BCS | BOUNC |
CLOAD | CONLO |
Systems
FRAME/FIX | FRAME |
SKEW/MOV | FRAME |
SKEW/FIX | FRAME |
Materials
M1_ELASTIC | MAT_1D TYPE 201, MAT_2D TYPE 101 |
/PROP/SPRING | MAT_1D TYPE 220 |
/PROP/SPR_BEAM | MAT_1D TYPE 223 |
M0_VOID | MAT_2D TYPE 100 |
M36_PLAS_TAB | MAT_2D TYPE 102/103 |
M44_COWPER | MAT_2D TYPE 102/103 |
M2_PLAS_JOHNS | MAT_2D TYPE 102/103 |
Properties
PROP/BEAM | PART, TYPE= BEAM |
PROP/KJOINT | PART, TYPE = KJOIN |
PROP/SHELL | PART, TYPE = SHELL |
PROP/SOLID | PART, TYPE = SOLID |
PROP/SPRING | PART, TYPE = SPRING |
PROP/SPR_BEAM | PART, TYPE = SPRING |
PROP/SPR_GENE | PART, TYPE = SPRING |
PROP/TRUSS | PART, TYPE = BAR |
Curves
FUNCT | FUNCT |
Control Cards
TITLE | TITLE |
OCTRL/ | |
/ANIM/DT | DSYOUPUT |
/TFILE | THPOUTPUT |
Components
PART | PART |
Contacts
CNTAC36 | INTER/TYPE7 |
Rigid Walls
RWALL | RWALL |
Time History
TH/SPRING | THELE |
TH/NODE | THNODE |
TH/FRAME | THLOC |
Sections
SECT | SECFO |
Groups
GRNOD/NODE | GROUP |
GRNOD/GENE | GROUP |
GRNOD/SUBSET | GROUP |
GRNOD/PART | GROUP |
GRNOD/MAT | GROUP |
GRNOD/PROP | GROUP |
GRNOD/GRNOD | GROUP |
GRNOD/SURF | GROUP |
GRNOD/GRSHEL | GROUP |
GRNOD/GRBRIC | GROUP |
GRNOD/GRSPRI | GROUP |
GRNOD/GRSH3N | GROUP |
GRNOD/GRTRUS | GROUP |
GRNOD/GRBEAM | GROUP |
GENOD/NODENS | GROUP |
GRNOD/FORMULA | GROUP |
Airbags
BAGIN | MONVOL |
