Element Orientation
You can select an orientation vector and apply it to all newly created elements.
View new features for HyperWorks 2020.1.
Edit the Parameter and Criteria files and define mesh controls using the Mesh Controls Browser.
1D mesh that allows accurate testing of connectors, such as bolts, and similar rod-like or bar-like objects that can be modeled as a simple line for FEA purposes.
Supported 1D elements.
Create 1D elements as a meshing tool or as a single element creation.
Select lines or nodes to create a mesh.
Select meshing parameters and biasing options.
In this optional step, you can select elements that can be assigned properties or a beam section.
Reorder the N1 to N2 sequence of 1D element nodes.
Define bar2 orientation vectors or orientation nodes.
Manually set offsets or adjust beams on plates.
Edit and release degrees of freedom.
Plot area moments of inertia and stiffness.
Use the Beams tool to create and edit standard beam sections, cross beam sections, and HyperBeam sketches.
A surface mesh or "shell mesh" represents model parts that are relatively two-dimensional, such as sheet metal or a hollow plastic cowl or case.
Volume mesh or "solid meshing" uses three-dimensional elements to represent fully 3D objects, such as solid parts or sheets of material that have enough thickness and surface variety that solid meshing makes more sense than 2D shell meshing.
Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply shapes for subsequent design optimization studies.
Create, review, and edit RBE2/RBE3 elements and MPC equations.
HyperMesh composites and tools.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
Use marine tools to create a stiffener mesh.
ON THIS PAGE
ON THIS PAGE
