Support Selection
Select lines or nodes to create a mesh.
From the guide bar, use the selector to choose either
Lines or Nodes.
When you select Lines, there is an automatic sort according to the following rules:
- Orphan lines – all lines are meshed as though the line mesh panel was behaving with default orientation derived from line Frenet frames.
- Unmeshed edges – seed based on size/density/biasing like orphan lines, but default orientation follows the local surface normal.
- Meshed edges – meshing behavior depends on whether you have checked the Match 2D mesh checkbox. Orientation depends on options.
- Optional:
Place a check in the Match 2D mesh checkbox.
When checked, the 1D mesh that is generated will conform with the edge mesh, regardless of meshing size and biasing. If unchecked, meshing is the same as unmeshed edges.
