Subsystem representations can be added from external sources such as solver
decks.
In the Subsystem Browser, right-click on a subsystem(s) and
select from the context menu.
Give the representation a name.
Select the correct file type.
Browse to the file that you want to add as a representation and select file
path.
Click OK.
You can choose whether this representation is also saved to the
library.
Note: Supported solver decks include: Radioss, OptiStruct,
Nastran, Abaqus,
PAM-CRASH 2G and LS-DYNA.
