Once you have created a subsystem and populated it with content, you can save the
representation locally or save a revision to the Subsystem Library.
Representations of subsystems are saved in solver deck format based on the current
solver profile.
In the Subsystem Browser, right-click on a subsystem(s) and
select from the context menu.
The Save Representation dialog opens. A checkmark
in the Available column indicates that the representation already exists in the
local repository. A checkmark in the Library column indicates that a revision is
already available in the Subsystem Library.
Edit the Major Revision and Study Revision columns to reflect the intended
revisions.
- Optional:
To save parts locally, deactivate the Save to Library
checkbox.
Click OK.
