Unload Subsystem Representations
Unload subsystem representations from a session.
View new features for HyperWorks 2020.1.
Subsystem representations allow a single subsystem to have multiple CAE representations that can be loaded into the session interchangeably.
Once you have created a subsystem and populated it with content, you can save the representation locally or save a revision to the Subsystem Library.
Subsystem representations can be added from external sources such as solver decks.
Subsystem representations can be added from external sources such as a subsystem library.
Add representations to the library if they are in session.
Subsystem representations can be loaded from the current HyperMesh session.
Subsystem representations can be loaded from the subsystem library.
Subsystem representations can be deleted from the current HyperMesh session.
Subsystem representations can be deleted from the Part library.
Use the Library Viewer to review subsystem library content.
Manage, control, and update Major, Study, and Library subsystem revisions using the Subsystem Library.
Also referred to as Postgres, PostgreSQL is an object-relational database management system with emphasis on extensibility and standards compliance.
Use the Organize tool to move or copy entities into their proper destinations.
Automatically group selected parts into part sets based on comparison method and criteria selected.
Define physical and mathematical characteristics of parts.
Create, review, and edit RBE2/RBE3 elements and MPC equations.
HyperMesh composites and tools.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
Use marine tools to create a stiffener mesh.
ON THIS PAGE
ON THIS PAGE
