FlexTools Menu
The FlexTools menu provides access to Flex Prep, Flex File Gen, Fatigue Prep, and Load Export.
Flex Prep | Displays the FlexBodyPrep wizard, which allows you to:
Flex File Gen | Allows you to create an Altair FLX file. This file references the .gra file, the .res file, and the N .H3D files used during animation. |
Fatigue Prep | Generates ADAMS output files from a flexbody transient run, which can then be used in nCODE Fatigue software. |
Load Export | An external module invoked from MotionView. This module allows you to take loads from an ADAMS run and create a tabular summary file or a Nastran input card for those loads. |
