SolverMode Menu
The SolverMode sets the current the active solver for MotionView.
This can affect modeling in the following ways:
  • When exporting the model to the solver in Modeling Mode, the currently active solver is the form of solver deck that will be exported.
  • Any parametric expression in the model that uses "if solvermode ==" will utilize the current solvermode to determine the state of the "if" condition. When the SolverMode is changed, the model is immediately updated for all aspects which are dependent on the current SolverMode.
From the SolverMode menu, you can access the following solvers:
  • MotionSolve
  • ADAMS
  • Abaqus
Selecting one of these solvers takes you directly to the Run Solver panel.
