Tools Menu
The MotionView Tools menu allows you to check a model for errors, select a writer and user mode, and access such panels as Reports, Templex Functions, and Options.
The following options can be accessed from the menu:
Option | Description |
Check Model | Searches for unresolved references and invalid data in the model. |
Freeze Output Ids | Performs the Check Model function and locks all MDL output IDs to their respective values resulting from Check Model. |
Import CAD or FE using HyperMesh | Allows you to generate detailed graphics for an MDL model using various source files. |
Model Identification Tool | Invokes the Model Identification Tool. This tool can be used to fit experimental data to analytical models for frequency, amplitude, and preload dependent bushings. |
CG/Inertia Summary | Used to obtain the total mass, center of gravity, and inertia of the models or bodies within a model. |
Custom Wizards | Select one of the following custom wizards from this menu:
Reports | Allows you to add predefined page sets to a session. |
MS UserSub Build Tool | Invokes the MotionSolve User Subroutine Build Tool. |
Templex Functions | Allows you to create and edit Templex functions |
Options | Displays the Options dialog, which allows you to set various options for your model. |
