Loading [MathJax]/jax/output/CommonHTML/jax.js
The addResponses Method
In this example, the objective is to find a design such that the RMS values of displacement, velocity, and acceleration are minimized. The RMS signals are computed as:(1)
R1=T0x2dtR2=T0˙x2dtR3=T0¨x2dt
Three responses of type RMS2 are created for defining these values. The objective to minimize the sum of these three responses (R1 + R2 + R3).
We also create a constraint (based on response type ResponseExpression) to make sure that the gain of PID controller would not increase infinitely. The constraint has the form:(2)
φ1k2P:k2Ik2D<0
The addResponses method for this model is shown below:
  def addResponse(self, time):
    We minimize the influence of disturbance on the block
    R1: Integral(acceleration**2,time)
    R2: Integral(velocity**2,time)
    R3: Integral(Displacement**2,time)
    R4: Constraint (1 - kp**2 - ki**2 - kd**2 < 0)
    # Define the desired profile
    zero_vector = [0.0 for i in time]
    targetValue = zip(time,zero_vector)
    # Measure the RMS acceleration deviation from desired
    expr = 'ACCZ({I},{J})'.format(I=self.block.cm.id, J=self.rm.id)
    self.R1 = RMS2 (
      label         ='acceleration',
      targetValue   = targetValue,
      measuredValue = expr,
    # Measure the RMS velocity deviation from desired
    expr = 'VZ({I},{J})'.format(I=self.block.cm.id,J=self.rm.id)
    self.R2 = RMS2 (
      label         = 'velocity',
    # Measure the RMS displacement deviation from desired
    expr = 'DZ({I},{J})'.format(I=self.block.cm.id,J=self.rm.id)
    self.R3 = RMS2 (
      label         = 'displacement',
    # The constraint
    self.R4 = ResponseExpression(
      label='sum of squares',
      function = '1 - kp**2 - kd**2 - ki**2',
      symbols = ["kp", "kd", "ki"],
      variables = [self.dv_kp, self.dv_kd, self.dv_ki]
