An explicit is solved by calculating results in small time increments or time steps. The size of the time step depends
on many factors but is automatically calculated by Radioss.
Composite materials consist of two or more materials combined each other. Most composites consist
of two materials, binder (matrix) and reinforcement. Reinforcements come in three forms, particulate,
discontinuous fiber, and continuous fiber.
Optimization in Radioss was introduced in version 13.0. It is implemented by invoking the optimization capabilities of
OptiStruct and simultaneously using the Radioss solver for analysis.
Interfaces TYPE3 and TYPE5 have some common problems.
Energy jumps
Bad contact treatment
Limited search algorithm
Energy Jumps
The gap used in interface TYPE5 (and TYPE3) is one sided and does not take into account the
edges. This can lead to energy jumps in cases of a large gap (Figure 1).
Bad Contact Treatment
Moreover, as the interface stiffness is constant, node penetration is allowed. This point can
lead to a huge error, especially if sliding occurs during the penetration. Figure 2 illustrates
how slave nodes are allowed to go through the shell mid-surface because of bad
contact treatment.
Limited Search Algorithm
With interface TYPE5 (and TYPE3), the detection of the closest master node is limited to the
segments topologically close to the previous one (topologically limited search
algorithm). The first search is done by Radioss Starter
to determine the closest initial master node, then the Engine determines the closest
master node, taking into account only the segments topologically close to the
previous one. This method is rather slow in CPU time, and it does not work very
well, especially if high curvatures are involved (Figure 3).
