An explicit is solved by calculating results in small time increments or time steps. The size of the time step depends
on many factors but is automatically calculated by Radioss.
Composite materials consist of two or more materials combined each other. Most composites consist
of two materials, binder (matrix) and reinforcement. Reinforcements come in three forms, particulate,
discontinuous fiber, and continuous fiber.
Optimization in Radioss was introduced in version 13.0. It is implemented by invoking the optimization capabilities of
OptiStruct and simultaneously using the Radioss solver for analysis.
This interface is used to simulate symmetric impacts between two surfaces.
Both surfaces are defined through the use of oriented segments; therefore contacts can only occur
on one side. Each node on both surfaces is considered as a slave node, and each
surface is considered as a master segment.
Contrary to interface TYPE5, interface TYPE3 has two master surfaces, therefore the contact
algorithm is performed twice. The first pass solves the penetration of nodes from
the first surface with respect of the second surface. The second pass solves the
penetration of nodes from the second surface with respect of the first surface. This
leads to higher accuracy compared to interface TYPE5, but more CPU time is
needed.
When contact is detected, an elastic spring is added and the spring stiffness is calculated using
both surfaces stiffness. Based on material and geometric properties, stiffness is
attributed to each surface, then the overall interface stiffness is
computed:(1)
The default value for the stiffness scale factor(s) is 0.2, for stability reason this value
should not be modified. However, if the ratio of over is greater than 100 (or lower than 0.01), it is
recommended to increase the stiffness scale factor to avoid too many penetrations.
The spring stiffness is constant, allowing slave nodes to pass through the mid-plane
of the master segment.
This interface does not enable auto-contact simulation, as a node cannot belong to both
surfaces.
Note: This interface is mainly used for shell plates
initially in contact. If the two plates are modeled with a gap between the two
meshes, it is better to use interface TYPE7; unless, if the two plates are
modeled without a gap, interface TYPE3 is a good choice.
