File Extensions and Formats
Radioss format 2020 uses the 12x extension format.
4x Extension Format | 12x Extension Format | Type | Format | Remark | Read by | Written by |
RunnameD00 | Runname_0000.rad | Starter input | ASCII | Starter |
HyperCrash HyperMesh |
N/A | Runname.radopt (13x extension) |
Optimization Input | ASCII | OptiStruct |
RunnameDnn | Runname_run#.rad | Engine input | ASCII | Engine | HyperCrash HyperMesh |
RunnameRnn | Runname_run#_cpu # [_C].rst | Restart file | Any | Default binary | Engine | Starter Engine |
RunnameAnnn | RunnameAnnn | Animation | IEEE binary | HyperView | Engine | |
N/A | Runname.h3d | Animation | H3D | HyperView | Engine (starting in 2018) or HvTrans through run script | |
RunnameTnn | if Radioss Engine option /TH/VERS/41
is used (default): RunnameTnn if Radioss Engine option /TH/VERS/51 is used: Runname_run#.thy |
Time history | Any | Default IEEE binary | HyperGraph | Engine |
RunnameTnnx | if Radioss Engine option /TH/VERS/41 is used
(default): RunnameTnnx if Radioss Engine option /TH/VERS/51 is used: Runname_run#_x.thy "x": letter (a to i) |
Runname@Tnn | Runname_run#_@.thy | MNOISE file | Any | HyperGraph | Engine | |
RunnameLnn | Runname_run#.out | Listing | ASCII | Engine | ||
RunnameYnnn | Runname_nnnn.sty or
RunnameYnnn according to /IOFLAG if Irootyy = 2: RunnameYnnn if Irootyy ≠ 2: Runname_run#.sty |
Output | ASCII | Starter | Engine | |
N/A | Runname_run#.sta | State file | ASCII | Starter | Engine | |
RunnameCnn | Runname_run#.ctl | Control file | ASCII | Engine | User |
- Max Runname length is 80 characters and the characters "/" and "\" may not be used.
- run#: Radioss run number (four digits) from 0000 to 9999.
- cpu #: number of SPMD processors (four digits) from 0001 to 9999.
- C: restart letter (see /RFILE/n in the Radioss Engine Input manual).
- In case of Single File Input, Engine options can be added into Starter file. See Single File Input for details.
- Though the current version of Radioss is able to read 4.x extension input files, output files always follows 12.x extension format.
