Common Problems
The following sections contain examples of some common problems in the contact interfaces and solutions to overcome them.
Nearest Master Node Found Incorrect
If the interface surface is not simply convex, the simplified master node search may find an incorrect nearest master node.
This problem occurs with interface TYPE3, TYPE6 and TYPE5 (master side only).
Nearest Master Segment Found Incorrect: B1
In some cases the nearest master node is not connected to the nearest segment.
This problem can occur with interface TYPE3, TYPE6 and TYPE5 (master side only).
Nearest Master Segment Found Incorrect: B2
This problem can occur with interface TYPE3, TYPE5 and TYPE6 (master side only).
Nearest Master Segment Found Incorrect: B3
If the angle between segments is less than 90 degrees, the incorrect nearest segment may sometimes be found, as in Figure 4.
This problem can occur with interface TYPE3, TYPE5 and TYPE6.
Impact Side Incorrect: C1
No Master Node Impact: D1
With TYPE5 interface, only slave nodes impact master segments; master nodes cannot impact slave segments.
