Enable Create Curves by File Dialog
From HyperGraph 2D, open the Build Plots panel.
If you want to only use the Build Plots panel, no further action is needed.
- From the Build Plots panel, click Dialog to display the Create Curves by File dialog.
The following message is displayed:
From now on, the Build Plots dialog will only be used instead of the Build Plots panel.
Accept the message to open the Create Curves by File dialog.
Note: Y Source is the default tab.
