Filter Load Cases
Do one of the following:
- From the Query tools, click the Loadcase tool.
- Right-click in the Results Browser and select Create > Derived Load Case then a load case type.
The Create/Edit Derived Load Case dialog is displayed. -
Click the Load case filter icon .
The text box is activated.
Enter a loadstep string and press Enter.
Note: The loadstep string that is used for filtering is not case sensitive.Only the loadstep(s) that match the string are displayed in the tree structure.Tip: Enter * into the filter text box and press Enter to display all of the loadsteps/simulations in the tree structure.
Once you done using the filter, close it by clicking the filter icon
again.
The entire tree structure is displayed.
