You can create as many sets/groups as you want, and the same entity can exist in
multiple sets. All sets that are created will be displayed in the Results Browser. Click the Sets drop-down menu to view the groups and
their components.
Note: Although component, node, and element sets can all be
created, only element sets are utilized in HyperLife
workflows.
Add a set in the following ways:
From the Utilities tools, click the Sets tool.
In the Sets panel, click Add.
Right-click in the Results Browser and select Create > Set from the context menu.
Make a selection in the modeling window then
right-click and select Create Set From Selection.
