Define a Set
From the Utilities tools, click the Sets tool.
Figure 1. - From the Set panel, select a set/group.
With the new set highlighted, change the input collector to the type of entity
you want to add to the set.
When a different type of set (group) is selected from the Sets list, the entity type shown on the Selection input collector is updated to correspond with the new set type that was chosen. Conversely, if the input collector type is changed, the set type of the highlighted group will be converted to the new set type that was chosen. For example, if the input collector of a component group is switched from Components to Nodes, all the nodes of the original components become the entities of the set. The set type is automatically updated, based on the entity type that is selected using the Selection input collector.Note: Although component, node, and element sets can all be created, only element sets are utilized in HyperLife workflows.
- Select entities using the input collector or pick directly from the screen.
Under Action, turn on the Add option.
Click Add or Remove to toggle the Add to Set/Remove from Set button between the two available options.
Click Add to Set.
The selected entities are added to the set and the number of entities in the set is listed for reference.
Figure 2. - Optional:
Remove select entities from the set.
- Under Action, turn on the Remove option.
- Select the entities that you want to remove.
- Click Remove from Set.
- Optional:
Redefine the entire set by clicking Clear.
All of the selected entities of the active set are cleared.Note: Repeat the steps above to select new entities for the set.
