Change the Display Options
In the Set panel, use the following options to change the display of the selected entities in a set.
  1. From the Utilities tools, click the Sets tool.
  2. From the Set panel, select a set/group.
  3. Activate the Show ID check box to display the IDs of the selected entities in a set.
  4. Click the Color box to change the color of the feature lines of the selected entities in a set.
  5. Use the Draw style options to select the drawing style for the active set.
    Option Description
    wire Draws a wireframe on the elements or components in the active set.
    Note: Available for Component or Element sets only.
  6. Enter a Draw size value to change the thickness of the wire.
