Takes information from a model and translates it to be graphed in the Build Plots panel.
Clears the request locators.
Draws the plots that are set in BuildPlots.
Finds the active file’s filepath.
Finds the sum of the entire file by making a checksum.
Finds the analysis type when Build Plots is in post mode.
Finds the value in the Y Component filter.
Gets one of the two component lists.
Gets one of the two data type lists.
Finds all the files that have been used in build plots.
Gets the layer list of the model within the file.
Finds the page layout number.
Finds the current layout option.
Finds whether the legend is on.
Finds the value in the Y request filter.
Gets one of the two request list.
Finds the current subcase.
Finds the list of subcases.
Finds the current value for the X data type.
Finds the current value for the Y data type
Finds the request (y data type binding) based on the result type that has been set.
Determines whether build plots is in post mode.
Selects a file to use in build plots mode.
Sets the value(s) for the X component.
Selects the value(s) for the X request.
Sets the value(s) for the Y component.
Sets the value(s) for the Y request.
Sets the Y component filter.
Sets the layout.
Sets the layout option.
Sets whether the legend is on.
Sets the output window.
Sets the chart style of the output window.
Sets the Y request filter.
Sets the subcase.
Sets the value for the X data type.
Sets the value for the Y data type.
ON THIS PAGE
ON THIS PAGE
