Determines if the statistics template is editable.
Finds the name of the statistics template.
Finds the text within the statistics template.
Sets the statistics template to be editable or not.
Sets the name of the statistics template.
Sets the text within a statistics template.
ON THIS PAGE
ON THIS PAGE
