sset export
Exports sets to a file.
sset export <file>
Arguments
- <file>
- Displays the file browser. Enter a name and select the directory to export the set to.
sset export C:\Documents\Set_1.txt
Use HWC commands in the Tcl Console.
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Marks entities on the active model.
Open files.
Result loading.
Result loading.
Save session content.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Adds entities to a selection set.
Creates an empty selection set.
Deletes a selection set.
Creates a set with displayed entities.
Imports a set from a file.
Renames a selection set.
Removes entities from a selection set.
Tracking system commands.
View manipulation.
sset export <file>
