ardi::item::property
Interact with items of type property.
Supported property names are: -name -value -type (create only) -command -setcommand -validatecommand -visible -enabled. All properties available can be passed via the "create" API. Specific property can be set using "set" API. eg command, setcommand, getcommand, validatecommand,help use getattributelist for complete list of attributes. Some of the attributes like -command,-getlistcommand are type specific. Queries list of available attributes.
-type
value: item ID. Not used.
ardi::item::property::create args
Creates an item of type "property".
-id (mandatory)
value: Parent item ID of type text, image, table, module, etc.
-key (mandatory)
value: unique key/name for the property
-name
value: "Display name of the property, if not specified key is used as display name"
-type
(defaults to str): Type of property
For a full list of property names, see above.
Returns
The ID of the item or tcl-error in case an error occurred during creation. i.e ardi::item::property create -id $parentid -key "MyKey" -name "My Property" -value "My Value" -type "str"
ardi::item::property::delete args
Deletes the item with the specified ID.
-id (mandatory)
-name (mandatory)
value: Name of the property
Returns
1 for ok
tcl-error in case of error i.e ardi::item::property delete -id $id
ardi::item::property::get args
Queries the value of one property.
-id (mandatory)
value: item ID. The item ID which is returned by the corresponding "create" API.
default value: ""
Returns
The value of the specified property or tcl-error in case of error usage: ardi::item::property get -id $id -property parent
ardi::item::property::getattributelist args
\ #usage ardi::item::property::getattributelist args
ardi::item::property::set args
Sets name and value of specific property.
-id (mandatory)
default value: ""
Returns
1 for ok
tcl-error in case of error i.e ardi::item::property set -id $id -setcommand "::setCommand" -command "::cmdcallback"
