Each design point set can have a different set of methods (design point method
entity) assigned to it.
You can add methods using the
context menu on a design point
set. This opens a dialog with a list of all of the registered functions. Methods are
registered by category. When you add methods from a list, a new entity design point
method is added as a child of the design point set. Certification methods can be one
of the following:
- INTERNAL
- Hard-coded method in HyperMesh. Not
customizable.
- DLL
- External dynamic library with methods exposed as EXTERN.
- COMPOSE
- Compose mathematical scripting language
(*.oml files).
- PYTHON
- Python functions.
- TCL
- Pure Tcl (procedures).
HyperMesh API's are not available.
All design points inside a design point set will be evaluated by all methods added to
it. There are a set of pre-defined methods included with the installation located in
an
.xml file. You can copy this
file from the installation in your directory and append your own methods.
Note: At
this stage, the
HyperMesh model is fully
instrumented. Remaining parameters will be runtime settings. The file can be
saved as a binary file (
*.hm). The binary file contains
everything to restore a ready to run database.
The Model Browser only lists design point sets and structural
properties. Design points are only visible from the Certification Browser. However, design point set deletion
from the Model Browser keeps track of design points and
design point methods deletion. Structural properties will not be
affected.
