Fuse Open Shells
Use the Fuse: Open Shells tool to automatically connect open shells to resolve penetrations/intersections, or prepare a BIW model for an electromagnetic analysis.
Fuse: Open Shells Tool
An overview of the Fuse: Open Shells tool.
Figure 3.
- Access
- Go to .
Options
- Fuse threshold
- Change fuse threshold.
- Remesh at connection
- Consider remesh at connection.
- Remove redundant patches
- Consider removing redundant patches.
- Redundant patch maximum width factor
- Change the redundant patch maximum width factor of fuse threshold value.
- Snap to features
- Consider snapping to features.
- Feature snapping tolerance factor
- Change feature snapping tolerance factor of fuse threshold value, within which the nodes positions resulting after the fusing of source and target elements can be snapped to features.
- Feature angle
- The maximum allowable break angle between adjacent elements.
- Fuse free edges only
- Fuse only free edges of the selected source and target.
- Bridge gaps
- Consider creating bridge elements between source and target.
- Projection type
- Select a type of projection from source to target.
- Remove target tails
- Consider to delete tails or small faces formed at the target after fusing source to target.
- Remove target tails tolerance factor
- Change the tolerance factor of fuse threshold value within which, if the width of the tail of the target tail face lies, it is removed.
