Animate Shapes
Animate selected shapes.
From the Mesh ribbon, Morph tools, click the Shapes tool.
Figure 1.The Edit Shapes dialog opens.
- Select a shape.
Click
The Edit Shapes dialog closes and the Shape Animation toolbar displays. - Play, pause or rewind the animation using the playback tools on the toolbar.
Set playback options as necessary by clicking
- Set Playback to loop, bounce, or once.
- Place a check in the Contour Plot checkbox to display the plot.
- Type a value for the desired number of frames.
- Type a value for the Animation speed.
- Type a value for Scale factor. This will change the height of the animation.
Redisplay the model in its current shape factor by clicking
To return to the Edit Shapes dialog, click
