Apply Scale Factors to Shapes
Apply a scale factor to change to the magnitude of the morphed shape.
  1. From the Mesh ribbon, Morph tools, click the Shapes tool.
    The Edit Shapes dialog opens.
  2. Right-click on a shape and select Apply by Factor.
  3. Enter a scale factor value then click OK.
    The morph is updated.
Tip: Enter a negative number to move the shape in the inverse direction.
